Madrix crashes after 20 minutes lots DVI eurolite 50
Deadcat
Post by Deadcat »
i'm running a save with a lot of cues and around 60% have a video layer along with multiple layers
after around 20 minutes madrix has frozen and the LED curtains locked up
cant get out of madrix and have to restart the laptop
the laptop is and i5
4gb ram
just trying to get the most out of the software without cooking the laptop by keeping my files as small as possible and lowering frame rate to 30
and cues go on for 30 seconds minimum so it doesn't switch around to quickly
with a curtain at 68x42
shouldn't be running into a graphics issue
little bit embarrassing on a clubnight and i have to reset the curtain on stage in front of 300 people then get into Front of house to restart the laptop
shedding any light on the matter would be great thanks!
Re: Madrix crashes after 20 minutes lots DVI eurolite 50
Hello Deadcat,
For a better analysis of this problem can you please send used MADRIX setup and also a logfile after you have load the setup to info[at]madrix[dot]com
To save the Setup go to "File > Save Setup as..." and enter a name.
To save the logfile please go in MADRIX to Tools > Logfile", click the button "Save As..." and enter a name for the Logfile.
alternative you can watch in your home directory under documents/MADRIX3/logs if there is already a lof file.
