submaster 253
dieter
submaster 253
Post by dieter »
sametimes if I press first button of submaster with mouse in any effect, then is set the value to 253. It's not good if the effect live on stage.
Re: submaster 253
thanks for this report we will check this out.
dieter
Re: submaster 253
Post by dieter »
You have check out?
My notebook have the same problem.
Re: submaster 253
yes i can reproduce this issue. We work on fixing this for the next release.
Re: submaster 253
Fixed in MADRIX 2.14.
