MADRIX Forum • Problem with CITP
Problem with CITP
Posted: Sun Aug 06, 2017 3:32 pm
by Tuple
i would like to run grandma2 onPC 3.3.2.2 and Madrix 3.16f on the same PC and use CITP.
For some reason the CITP Server doesn't work.
gma2 has the IP 2.2.2.2 which is a physical network card.
madrix has the IP 2.2.2.10 which is a virtual loopback adapter.
Subnet Mask is 255.0.0.0 and the firewall is off.
The IP-ranges have to be like this because gma2 communicates with another external computer.
I can send artnet from gma2 to madrix without problems, but gma cant recognize the CITP server of madrix which runs on 2.2.2.10.
Any ideas how to fix this?
Re: Problem with CITP
Posted: Tue Aug 08, 2017 2:08 pm
Hello Tuple,
It is not possible to use a virtual network adapter to exchange CITP information between MADRIX and the grandMA.
If you want to exchange CITP data between MADRIX an the grandMA on one and the same PC, you have to use two physical network cards and connect this two cards. Of course you can connect it to a switch. Now you will be able to send CITP data between both softwares.
Posted: Tue Sep 19, 2017 6:45 am
by bew
Did you has activate the media server on gma???
CITP can work as media server on gma
