MADRIX Forum • Madrix Demo Mode
Madrix Demo Mode
Posted: Sat Sep 16, 2017 6:27 pm
by djcharlie
Hello, I bought an Artnet - SPI decoder and I try to used with the demo versión but I couldn't used. Is the demo version ready for use with this controller? How can I setup the output to uses with 2812 led strip? Thanks
Re: Madrix Demo Mode
Posted: Mon Sep 18, 2017 10:28 am
Hi.
It is possible to use the demo version of MADRIX 3 to test your hardware.
Please see here for the limitations of the MADRIX 3 demo version:
http://help.madrix.com/m3/html/madrix/h ... x_key.html
And please learn here step by step how to enable Art-Net and configure the connection to Art-Net hardware:
http://help.madrix.com/m3/html/madrix/h ... e_net.html
Posted: Wed Sep 27, 2017 7:07 am
by kelvin yap
hi,may i know how to remove the rotating X on preview?
Posted: Wed Sep 27, 2017 8:17 am
Hello kelvin yap,
The "Rotating X" will be removed if you connect a MADRIX KEY on the PC which unlocks the DVI output of MADRIX.
MADRIX KEYs which unlocks DVI output are the MADRIX KEY dvi start, MADRIX KEY dvi entry, MADRIX KEY dvi, MADRIX KEY professional, MADRIX KEY ultimate.
Posted: Wed Sep 27, 2017 11:48 am
by kelvin yap
i have the madrix key.but how to unlock the dvi output?
Posted: Thu Sep 28, 2017 3:32 pm
Hello kelvin yap,
The DVI output of MADRIX will be unlocked with a MADRIX KEY which is able to output dvi signals.
If you are using a MADRIX KEY which unlocks only DMX, the dvi preview will still be locked with the cross.
What MADRIX KEY/MADRIX license do you use? You will find the name of the license in MADRIX under "Help > About".
Posted: Fri Sep 29, 2017 6:31 am
by kelvin yap
ok.thks for the info.
