How to re-locate my record files
Posted: Wed Apr 10, 2019 8:52 am
5 Best Long Range Baby Monitors That Will Give You Peace of Mind
A parent always wants the best for their children. And baby monitors keep working wonders with their capability to keep your baby near you. Long distance baby monitors are crucial when you are far away from your baby. Before buying a baby monitor, you need to know what to look for so that you get the best one for your child.
✪✪✪ Read More: Best Video Baby Monitors - Top Baby Monitor Camera
Let's look at some of the best points you should be consider.
Why go for a long distance baby monitor?
When your baby is napping, you won't want to be limited to one place so that you can hear her. If you have two or more babies, you can't be in two different places at once.
With a long range baby monitor, you can hear and see your bundle of joy wherever you are in the house. You can take one kid out and play while the other child sleeps.
You can also entertain your friends outside the house, knowing that your baby is safe.
What does long-range mean?
Most monitor ranges are measured in an open field. It means an open area without obstructions.
This doesn't always happen inside house. There are doors, walls, other obstructions that can get in between the transmission unit and the monitor. This means that it's possible that the actual range would be less than what is stated as open field range.
If you want to know the actual range, you can read customer reviews. It's a great source of information.
Important features to consider
When it comes to selecting the right long-range baby monitor, there are few things you can think about.
Video or audio
Generally, an audio signal tends to travel better when compared to a video feed. But you should know that it depends on the obstructions between the parent monitor and the transmission unit. That means that one monitor might work well in one home and might not work as well in another. You can go for an audio monitor if you don't want to be stuck to a video monitor.
Frequency
Most monitors rely on designated frequencies. If there are other electricals on the same frequencies as your baby monitor, they can affect the transmission of signals.
Analog or digital
Digital baby monitors use Digital Enhanced Cordless Telecommunications (DECT), which makes them resistant to interference. That's not the case with analog baby monitors.
Privacy
A close monitor can easily intercept analog baby monitors on the same frequency. Any receiver can also intercept it. That means that a video feed of your baby can be intercepted, and people can watch your baby. However, that's unlikely. This is also the case with audio monitors. People can hear and speak through your monitor.
Alarms
Most monitors come with an alarm that alerts you when you get out of range. This ensures that you don't move so far away that you miss alerts from your baby.
Size of the home
If you have a smaller home, a long-range monitor might not matter that much. But if your home is bigger, or if you go outside often, you will need a longer range.
Lights
With a baby, sleep can be precious and rare, so consider the blinking lights and think about how it might affect your baby’s sleep.
Battery life
Having a device with a longer battery life will ensure that you won’t have to charge it too frequently or have it glued to a power source too often. Just make sure that the baby monitor is plugged in or fully charged before going to bed. That way, you won't be woken up by noisy alarms when the battery drains.
Best Long range Baby Monitor Reviews
Different long-range monitors can come with various features, and choosing the best one can be challenging. That's why we have made that easier for you by giving you some of the best long distance baby monitor brands in the market:
Infant DXR-8 Video Monitor
The Infant Optic monitor has a fantastic range of about 700 feet. It also has an incredible sound quality, a 3.5-inch LCD screen, and little interference, which ensures that you can see your baby from any location in your home.
The alarm systems alert you when you move out of range Its camera can be zoomed, panned and tilted through 170 degrees from the monitor. If you want better camera coverage, you have the option of adding extra cameras to meet your needs.
Pros
This
The Best Baby Monitor for twins comes with an automatic IR night vision. Quality matters. If you want a monitor with excellent video and sound VTech offers video monitors with great audio. You also get good field range of up to 1,000 feet. Its DECT technology helps in cutting out background noise like music and avoids interference.
Pros
The VTech monitor can be a perfect choice when you are on a small budget but looking for the best long range audio baby monitor. It has an excellent range of 1,000 feet in open space and 160 feet at home. This lets you do laundry, cook dinner, or take a few minutes in the garden without worrying about your baby. The DECT technology eliminates interference ensuring that you have crystal-clear audio.
Pros
This monitor has 160 feet range while indoors and 900 feet on open coverage. It comes with a 2.4 GHz connection for uninterrupted signal and privacy. It also comes with a temperature sensor, IR night vision, built-in lullabies, and a two-way talkback feature.
Pros
The Philips monitor offers fantastic sound quality. With the DECT technology, there cannot be interference even for long distances. This ensures that transmissions are secure and safe.
The talkback function enables you to talk to your little one and soothe them. The nursery unit can monitor the room temperature. It comes with a soft night light and five lullabies. The lights let you feed your child at late hours of the night without hitting things.
Pros
Conclusion
The products we have reviewed offer excellent sound, and the ones that offer video feed have fantastic video. Their range is stable and can allow at least 150 feet indoors and up to 1,000 feet outside. They also come with other amazing extra features. Anything that enables you to move freely around your garden and home, but keeps tabs on your baby is priceless.
Video or audio
Frequency
Analog or digital
Privacy
Alarms
Size of the home
Lights
Battery life
Pros
- Good battery life
- 150 feet range without obstruction
- Audio-only setting
- Changeable camera lenses
- There can be interference from the different gadget in the same frequency
This
Pros
- Comes with five built-in lullabies
- Temperature and out-of-range alarms
- Split-screen viewing
- Additional camera/s can interfere with primary camera's audio
Pros
- Nightlight on the nursery unit
- Talkback feature
- Great audio without interference
- Amazing range outside and in
- No battery on the nursery unit
Pros
- Can take up to four cameras
- Power saving mode for extended battery life
- Clear picture quality at a reasonable price
- The power cord can be too short
Pros
- Long-lasting batteries
- DECT technology
- 100 percent secure
- Crystal clear sound
- Range of 150 feet at home and 900 feet in an open space
- Night-light and lullaby function cannot be controlled from the parent units
Conclusion
