MADRIX Forum • Layer delay time
Layer delay time
Posted: Mon Jan 11, 2021 5:39 pm
by HBonello
How can I add a delay to start each layer at different times when I select a storage place? 😅
Re: Layer delay time
Posted: Tue Jan 12, 2021 8:57 am
Hello HBonello,
The layers of the activated Storage Places are always playing. But you will be able to fade in (change the opacity) of the desired layers after a "delay" time with the help of the Storage Place Chaser.
More about the Storage Pace Chaser you can learn under the following link:
http://help.madrix.com/m5/html/madrix/i ... haser.html
If you want to change the opacity of layers please change the "Parameters" to "Layer Visibility Settings". After changing the settings you can create the desired chaser.
Posted: Tue Jan 12, 2021 6:11 pm
by HBonello
Thank you @Guertler,
I know the chaser option and I tried it before posting, but for my effect it didn't work because i'd like to have the start of the effect delayed in relation the the others.
I also tried to have the chaser delaying the layer from speed 0 to X but it also didn't work.
Any way to accomplish this?
Posted: Wed Jan 13, 2021 1:07 pm
Hello HBonello,
Can you please explain a bit more what you want to achieve?
Maybe we will find a solution with the help of the MADRIX Macro in combination with the MADRIX chasers.
