MADRIX Forum • 2.14e fullscreen refresh
Posted: Mon Aug 12, 2013 12:20 am
by cg
I just had the 1st show with v2.14e and there is an annoying issue. I use 5 channels of DMX remote while the GUI stays in full screen mode.
Whenever the submaster A or B level is changed via DMX remote nearly the whole screen gets slowly refreshed, leaving the GUI unusable for about a second. Speed A/B and Audio level (the other 3 DMX remote channels) work fine.
This has been working fine in the previous 2 versions of madrix and I can't think of anything else changed in the hard- and software setup.
DMX in is a Madrix Neo,
just a small matrix of 8x5 pixels
Re: 2.14e fullscreen refresh
Posted: Mon Aug 12, 2013 10:53 am
Hi cg,
Thank you for your report!
To investigate further,
can you please send us to info[at]madrix.com:
- Your MADRIX Setup File
- Your DMX-IN Remote Configuration [*.mdrx]
- and the MADRIX Logfile, created at a time when the issue occurs?
And one question: which device/controller/console did you connect to the MADRIX NEO?
Thank you very much!
Posted: Tue Aug 13, 2013 7:48 am
by cg
thanks for your reply, I'll send details next week (holidays...)
the DMX controller is a GLP scenesetter
Posted: Wed Aug 21, 2013 10:16 pm
by cg
just sent you 3 files...
on my backup PC there still is Madrix 2.14a installed which fails to open the setup file, but when I use the dmx remote config in any setup there it works without that annoying screen refresh.
thanks in advance...
Posted: Tue Nov 19, 2013 5:55 pm
Can you please test again with MADRIX 2.14f to see if there are improvements?
Posted: Sun Nov 24, 2013 7:30 pm
by cg
Just did a quick test and it seems to be fixed! Thanks a lot!
