Simultaneously Control Independent Groups
Re: Simultaneously Control Independent Groups
Post by Schulze » Thu Oct 29, 2020 5:51 pm
Hi Quinton,
1) "Ok got it, out of curiosity how many recordings (storage places) can i record to in the Auras?"
- The maximum number of recordings recordings depends on the storage capacity of the SD card.
2) "Also I assume each storage place will be triggered by a diff HTTP command?"
- Yes, you can assign a customized command, which triggers an action. The action could be for example a playback of a certain Cue.
Quinton
Post by Quinton » Tue Nov 03, 2020 12:51 pm
Thanks Schulze, when you release the unit will i am guessing you will also be releasing full documentation for all HTTP commands?
Post by Schulze » Wed Nov 04, 2020 7:54 pm
Hi Quinton,
Yes, you will find all the necessary information in the manual. As I said before, you will be able to create customized HTTP commands, which are triggering certain "Actions".
The following Actions will be available:
  • Cue - Calls a specific cue [requires a value to choose which cue].
    Next Cue - Skips to the next cue.
    Previous Cue - Skips to the previous cue.
    Play - Starts the playback.
    Pause - Halts the playback.
    Toggle Pause - Pauses the playback or starts it again; depending on and in contrast to the current status.
    Stop - Stops the playback entirely.
    Intensity - Sets the master brightness ranging from 0 to 255 [requires a value to choose which level].
    Speed Scaled - Sets the speed ranging from 1 to 1000 in % [requires a value to choose which level].
    Speed Direct - Sets the speed to the exact value that is received [requires a value to choose which level; up to 255].
    Intensity Group 1 - 8 - Controls the intensity groups ranging from 0 to 255 [requires a value to choose which level].
    Record - Starts the recording process.
    Speed Increment - Increases the speed ranging from 1 to 1000 in % [requires a value to choose which level].
    Speed Decrement - Decreases the speed ranging from 1 to 1000 in % [requires a value to choose which level].
    Intensity Increment - Increases the master brightness ranging from 1 to 255 [requires a value to choose which level].
    Intensity Decrement - Decreases the speed brightness from 1 to 255 [requires a value to choose which level].
    Intensity Group 1 - 8 Increment - Increases the group brightness ranging from 1 to 255 [requires a value to choose which level].
    Intensity Group 1 - 8 Decrement - Decreases the group brightness from 1 to 255 [requires a value to choose which level].
Quinton
Post by Quinton » Sun Nov 15, 2020 10:50 am
Thanks Schulze, i was just looking through the manual, with the http commands would it be possible to provide a little more information as to usage or examples/tutorials for this?
Post by Schulze » Fri Nov 20, 2020 5:50 pm
Hi Quinton,
We will add tutorials regarding this topic in the near future. HTTP remote allows you to trigger certain actions on the AURA(for example start the playback of the Cue List, start a recording, manipulate the intensity level, etc.) remotely (from a remote location) using a device, which needs to have network access to the AURA. This could be for example a computer.
There are some examples in the chapter "Remote Event Settings":
http://help.madrix.com/m5/html/madrix/i ... x_aura.htm
Back to top
