controlling MADRIX with a MIDI keyboard?
girl_tm
Post by girl_tm »
Is it possible to control MADRIX via a MIDI instrument such as a keyboard?
Yes, via Creative Prodykeys protocol
Yes it is possible.
If you have connected the Keyboard via MIDI with the PC, select the Creatvie Prodikeys protocol.
In the future you will be able to set up the Midimap for yourself and your needs.
girl_tm
Post by girl_tm »
This is great. So, on the other side, if I want to build my own LED light display panel for shows, what piece of hardware should I buy to hook it up to my computer so that it can be controlled by Madrix via my MIDI keyboard?
Ok, what exactly you want to control with your Midi Keyboard.
There are two way with MADRIX you can use it.
First as a Midi Keyboard to play Music which MADRIX analyse to control M2L (Music2Light) Effects.
Second as a Midi Controler like Numark Total Control (look at Midi Controler page of this website) to control the live functionality of MADRIX, like the selection of a Storage Place, auto fade, fade type and so on.
To the first part of your question.
MADRIX can controls light fixture (mostly led) which understand DMX or have a DVI driver.
I think in your case we speek about DMX.
You are familiar with DMX?
This means if your led
girl_tm
Post by girl_tm »
Thanks very much for your help. I will explain the project further. I want to build a custom LED grid as a background for shows with my band. It will look something like this: http://blogs.msdn.com/coding4fun/archiv ... 18683.aspx
Instead of having to write my own software to control the grid, I would like to use Madrix. So, if it is possible to use Madrix for this kind of grid, then I need to know what hardware or components I need to buy to hook up the grid with the computer.
Could you please let me know about that?
Am I able to try this with the demo version of the software?
Thanks again!
If you build up the grid with led driver which support DMX512 as input you can use MADRIX very well for control.
In this case you need a DMX interface, for example our USBone. It
girl_tm
Post by girl_tm »
Ok, this is great info, thank you! I am familiar with DMX and will check out the USB converter you mentioned.
Thanks again!
List of DMX Interfaces supported by MADRIX
For a list of interfaces supported by MADRIX take a look here
http://www.madrix.de/index.php?topic=DMX512_1-1-3
VJ Pat
Post by VJ Pat »
Madrix is also with the Behringer BCF2000 compatible?
Yes MADRIX is compatible witrh Behringer BCF2000.
Open the Device Manager.
Select the Midi Input Page.
Inside the Remote Control section enable the Midi Device and select the Behringer BCF2000 (Fader) config.
have fun.
