Reset 'Open options' to default when opening a saved setup
Geert
Post by Geert »
When you open a setup and deselect one or more of the 'open options', then close Madrix and reopen, the deselected options are still deselected. I guess this is probably by design, but i would like the options to be reset to default 'selected', so when opening a setup, you don't have to check everytime if everything is selected. When i want something to deselect, i know that before i open the setup.
Re: Reset 'Open options' to default when opening a saved setup
hmm,
i am not sure about this, yes it is designed to act as like as you described.
Maybe we can offer buttons for select all and deselect all to make it more comfortable. What did you mean?
Geert
Post by Geert »
Ofcourse, if you make a toggle in preferences>options>startup options, which says "always reset open options to default" everybody is happy.
What you write is different to the option i mean but it sounds interesting !
