Madrix effect
ayaoye
Madrix effect
Post by ayaoye »
Hello!
Does anyone know how to make this effect?
https://vimeo.com/272455413
Re: Madrix effect
Hi there!
Unfortunately, the link is not working.
Thanks.
hansolo
Re: Madrix effect
Post by hansolo »
now it looks
snaido
Re: Madrix effect
Post by snaido »
You need to create 2 fixture types in the fixture editor. One for RGB and one for the motor movement and speed. Add them to your matrix and separate them in groups so that you can apply different effects to color and motor in different layers and save them as presets. Hope this helps. We do them quite regularly.
hansolo
Re: Madrix effect
Post by hansolo »
hello, thanks for answering ..
this was already done but we still can not make the movement that appears in the video.
What is the effect in madrix that makes this movement?
snaido
Re: Madrix effect
Post by snaido »
looks like gradient animated in different sequential directions to me. Radar with an off center could also look similar.
hansolo
Re: Madrix effect
Post by hansolo »
hello!
Hi. I have tried the two effect options that you mentioned to me and none has given me the expected result, do you have any other effect that can provide me with the expected result?
schuetze
Re: Madrix effect
Post by schuetze »
Hi hansolo,
The movement in the video is basically a 3D plane with a smoothly rotating surface normal.
Thinking of it as a height map, I would suggest to use a linear gradient from white to black. With the aid of the map settings, you can then rotate the effect. The rotation can be animated automatically. You should also upscale the effect a little bit to avoid black corners when rotating.
I have attached a zipped Storage Place "Gravity.mspx" which demonstrates my approach.
Kind regards,
Matthias
Gravity.zip
(1.71 KiB) Downloaded 5013 times
