Activate stored buttons
nmohanlighting
Post by nmohanlighting »
Is it possible to activate Madrix stored buttons (like cues) by external midi time code?
Re: Activate stored buttons
Hello nmohanlighting,
You can easily trigger the Storage Places via Time Code when you are using the MADRIX Cue List. That means you add all desired Storage Places to the Cue List and set for every Cue a desired time code. When now MADRIX receives the Time Code it will active the corresponding Storage Place.
Under the following link you can learn more about the work with Time Code:
http://help.madrix.com/m3/html/madrix/i ... list_.html
Please scroll to the Time Code section
nmohanlighting
thank you for your reply sir, of course I am running that way only
kind regards
