Only a few DMX Chanels routed to the Output
Otto Events
Post by Otto Events »
Hi everybody,
Is there a possipility to just send selected DMX Chanels over the DMX Out?
I use the Enttec USB Pro and I just want control the CMY from my Washlights. So if I rout 3 Channels only to the CMY Chanels, it is possible to control the CMY but all the other Chanels in that DMX Universe go to 0 that infects also the Pan/Tilt movement and other functions. I would like to use the DMX In on my Lightdesk.
An other question is how to invert selected Chanels, so the RGB controls the CMY, it´s written in an other topic, but hell I´m too stupid...
Thanx for your help ;-)
Re: Only a few DMX Chanels routed to the Output
If i understand your request correctly, yes it is possible.
You have to use the MADRIX Fixture Editor to set up the fixture you have in mind.
Within the Fixture editor you can decide which channels are color channels and if this channel is inverted. Also you are able to define fixed values like zero for the channels.
Please take a look onto the MADRIX Fixture editor.
On the other hand you can use a dmx merger instead of routing the signal trough your desk.
