Issue: CSV cue list import.
2004dianecrowe
Post by 2004dianecrowe »
You have many choices of massage chairs on the market today. This is especially true for the high-end luxury models. A number of the top companies produce these chairs with a wide variety of differences in the technology used. One of the more advanced massage chairs on the market is the Sanyo massage chair.
The high-end Sanyo massage chair is the DR 7700 model. This massage chair comes with a number of advanced technological features. Many of these features are used to provide a more thorough and customize massage based on your body type and your current state of health.
The DR 7700 massage chair comes with a stress sensor. The user will cup a mouse-like devise with their hand. The advanced technology of this chair will read the pulse rate and perspiration of the user. It is then able to determine where you have stress points in your back.
Last edited by 2004dianecrowe on Mon Aug 31, 2020 3:09 am, edited 2 times in total.
Re: Issue: CSV cue list import.
Hello 2004dianecrowe,
Welcome to the MADRIX Forum.
The Time Code value in the Cue List CSV file format is millisecond based. That means you have to convert every desired Time Code or Duration into milliseconds. In case of using Time Code you addinal need to pay attention about frames. In case of a frame time different from 0 you need to have the Time Code Format in mind.
For example the Time Code should be 00:00:36:05 at the Time Code Format 30 FPS.
Now let us calculate:
36 s are 36000 ms
Convert frames in millisecond:
1000 ms per second / 30 FPS (frames per second) = 33.3 ms per frame
5 frames x 33.3 ms per frame = 166 ms
So we have to set 36166 (36000 ms + 166 ms) as value for this example.
