MapDlgGetMapPixel()
pjveltri
MapDlgGetMapPixel()
Post by pjveltri »
How does one use MapDlgPixelGetMapPixel() to give the x,y,w & h a starting value?
I'm trying to post it into an int named x and am unable how to figure out how to use it at all!
Help Please!
PJ
Re: MapDlgGetMapPixel()
Hello pjveltri,
To give a start value for the map you have to use the script function: "MapDlgSetMapPixel(int x, int y, int w, int h)" These function allows you to set the start possiton for X- and Y-coordinate, the width (Size X) and the height (Size Y) for the map.
If you use the MapDlgGetMapPixel(int map[]) function you will get the current mapping setting for the layer with the positions (X- and Y-coordinate), the width and the height. Please pay attention: the values will be saved in an interger field.
