LUNA16 - DMX OUT 9-16 DOES NOT WORK (NO SIGNAL)
hakan.koc.jtk
Post by hakan.koc.jtk »
Hi
LUNA16 + MADRIX 5 (Basic Licence)
No Signal Output at DMX Outputs 9-16; where Outputs 1-8 work fine (both tested with USB & Art-Net,Ethernet
All outputs ON (1-16); tested also with DMX In ON or OFF
Tested with default MADRIX Setup or custom patching setup
DMX Watcher shows DMX Out as per the program, yet no physical output signal at the Luna16 Outputs 9-16
DMX signal is tested with Swisson XMT-350
Looking forward to receiving your support
Re: LUNA16 - DMX OUT 9-16 DOES NOT WORK (NO SIGNAL)
This issue report was also send via e-mail.
It was a hardware issue especially in this LUNA 16.
The issue has been already solved.
richardshodges
Post by richardshodges »
Tile Installer
Hey! May I know how did you fixed this issue?
Richard
Hi richardshodges,
In such cases the device needs to be sent back to us alongside with an filled-out RMA document. The device will be then repaired in-house. If you open or manipulate the device yourself, you will loose warranty. Just contact us if you are facing hardware issues!
olivia1443
Post by olivia1443 »
Schulze wrote: Fri Nov 12, 2021 2:53 pm Hi richardshodges, Mary
What would I do now? My partner opens the device himself.
olivia1443 wrote: Tue Apr 26, 2022 11:16 am What would I do now? My partner opens the device himself.
Please contact our team via e-mail at info[at]madrix.com
olivia1443
Fritzsche wrote: Tue Apr 26, 2022 11:50 am
olivia1443 wrote: Tue Apr 26, 2022 11:16 am What would I do now? My partner opens the device himself. lead generation
Will do that, Thanks to you. :)
richardshodges
www.chandlerconcreteworks.com
Sorry if it took me so long to reply, and yes, it worked. Thank you so much for your assistance.
richardshodges
spa design
Did you receive my email? I didn't get any response from your team. Thanks.
Hello richardshodges,
We didn't receive your e-mail. Can you please send it again?
Back to top
