so...how do i patch this
danirom
Post by danirom »
i might be the most idiot guy right now,but the manual didn't help me very much. so..i have a ceiling and a bubble wall. The ceiling is made out of 6 panels and each panel has 5x10 leds, so the whole ceiling is 15x20 leds. the bubble wall is made out of 16 panels and each panel is 2x2 leds. so the whole wall is 16x4 leds. i'm not sure if this is clear,but if it is...can someone help me patch this?thank you:)
Re: so...how do i patch this
Hi danirom,
no worry we will help you.
I recommand to set up the virtual matrix size to 16x24.
In the top 20 rows place your ceiling of 15x20 pixel, so you will have 1 pixel space on the right side.
Next place your bubbles at the bottom 4 rows.
After this you have to map two layers onto this settings if you have in mind to place two differnt effects onto this two walls.
I hope this heps you.
