Rodin II & madrix
dieter
Rodin II & madrix
Post by dieter »
Hi madrix team,
I found a rodin II interface in my clobber box . Can use this with madrix for send dmx data? Do you have driver for this interface?
Re: Rodin II & madrix
Hi dieter,
yes with MADRIX 2.8 you are able to use the Rodin II for sending DMX data.
All you need is a gender changer, because the Rodin II is designed as a DMX-In interface.
The driver you can found on the MADRIX installation CD (if you have one) or after the installation of MADRIX inside the MADRIX programm folder under driver/peperoni.
dieter
Post by dieter »
It's fine,
but I haven't a madrix cd only download from this website.
I'm afraid can't found a file or directory with name peperoni on my harddisk.
Can you help me? Or have an download link for this interface driver?
I found many of links and comments for this interface but no driver files.
ok, maybe you have to reinstall MADRIX, because within the MADRIX installation (it doesn´t matter if it is the installation from CD or the Website) you have a option to install the interface drivers.
So maybe you have not checked this option within your installation and therefor you found nothing on your hard disk.
dieter
Post by dieter »
yes I found it in C:\Program Files\MADRIX\driver\peperoni
yes interface running fine
thank you for fast help
