Help with OVI Maps and DVI output LED screen
lenhoc91
Post by lenhoc91 »
I have to follow instructions but problems led out to the screen.
I selected HDMI output DVI box,
DVI out the LED screen with RJ45 cable
LED screen with card recipients through linsin
But Led screen displays only the 2nd desktop computer from not getting DVI from Madrix
look forward to supporting more
to ask is Madrix supports full color LED chip type 6803 not
Re: Help with OVI Maps and DVI output LED screen
I gues you did not open a DVI preview in MADRIX.
Please read how to do this in the manual
http://help.madrix.com/m3/html/madrix/h ... tions.html
lenhoc91
Post by lenhoc91 »
thank you.
I want to ask is linked to support LPD full color LED 6803 is how to connect
If you want to connect to a specific type of LED, please search for so-called DMX-to-SPI converters/decoders, which should support the required type of LED on the one hand and DMX512 on the other hand. Then, you can use a MADRIX DMX512 hardware interface to connect to this converter/decoder. In this way, you can connect a lot of LED products to MADRIX.
Does that help?
lenhoc91
Post by lenhoc91 »
thank you very much.
