Spout CAM seems to be broken :(
dijjital@gmail.com
Post by dijjital@gmail.com »
Spout CAM seems to not be working in Madrix5. Really sucks too because it's essential to my workflow. SCE Capture just doesn't recognize it as an input source. Could this be a 32-bit vs 64-bit compatibility issue? Would love it if this could get a fix sooner rather than later!
Re: Spout CAM seems to be broken :(
Hello dijjital@gmail.com,
Thank you for reporting it.
You are right. The "SPOUT camera" is a 32 bit device with a 32 bit driver. MADRIX 5 is a 64 bit software. Because of this reason it is not possible to find the "SPOUT cam" as capture device in MADRIX 5.
As workaround you can use the the "SPOUT receiver" application which will installed when you installe "SPOUT" and capture this receiver window with the MADRIX "SCE Screen Capture" effect.
