Load csv with cyrrilics
ledtinker
Post by ledtinker »
I have an issue when I try import csv-file in madrix cue-list: in description column I see question marks instead of cyrrilic symbols in program interface. How can I possibly resolve an issue?
Thx in advance
Re: Load csv with cyrrilics
Hi.
Please mask your descriptions with so-called text delimiters. During the CVS import process in the MADRIX Software, you can then select which text delimiters you have used, for example "TEXT_EXAMPLE". In this case, the delimiters would be the double quotes.
Could you also please check if your file is encoded as UTF-8?
