Madrix crashes on launch
lightlab
Post by lightlab »
I had Madrix 3.6d, but it would crash on launch. Updated to 3.6e and it opened. Updated my Nebula firmware. Tested LEDs in Resolume--no output. Started up Madrix again and it crashes on launch again.
Windows 7
Resolume 5
SK6812
Problem signature:
Problem Event Name: APPCRASH
Application Name: MADRIX.exe
Application Version: 3.6.5.1
Application Timestamp: 58a1c8f3
Fault Module Name: igd10umd32.dll
Fault Module Version: 8.15.10.2538
Fault Module Timestamp: 4e803d76
Exception Code: c0000005
Exception Offset: 00011909
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Re: Madrix crashes on launch
Hello lightlab,
It seems that the "igd10umd32.dll" makes the trouble. This DLL is part of the intel graphic card driver. Please make sure that you have installed the latest graphic card driver.
Can you please tell use which graphic card you are using in this PC?
lightlab
Post by lightlab »
Guertler wrote:Hello lightlab,
Problem solved with a driver update, thank you!
lightlab
Post by lightlab »
Although the driver update initially solved the issue, occasionally the same error appears--but not every time. Usually Madrix software starts with no problem.
